Thermador DWHD640JFM/B3 Pump Replacement for E09 Code
olejnic
Los Angeles
DWHD640JFM/B3
Thermador
The dishwasher has error code E09, and I have the new pump to replace the old one. How do I access the pump? There doesn't seem to be a way from the rear of the unit?
olejnic
Los Angeles
After unnecessarily removing the front panel, I realized that if you take off the side panel by removing the front side trim piece. Then the pump is readily accessible.
Which pump? The circulation pump? Or drain pump?
Please double check your model number again.
DWHD640JFM/B3 does NOT pull up as good.
DWHD640JFP/B3 does pull up as good.
