FIXED Thermador MBBB/01 Microwave doesnt heat, Magnetron?
sod
Minnesota
MBBB/01
Thermador
Thermador MBBB/01 model microwave. Has the following noise (video attached) when started and doesn't heat. The light comes on and the tray spins. Suspect it a bad magnetron.
I found a LG magnetron that is supposed to work. Part number is
6324W1A001L​
Can anyone confirm this LG part will work.
The unit is built a oven/microwave combination. So I would like to confirm problem and get part prior to pulling from wall cabinet. So help is most appreciated
RepairClinic says you can: The manufacturer has replaced part number 6324W1A001L with part number EAS42812937
You Bet!
