Thermostat Digital Screen is Blank - Is it the AC Unit or the Furnace? How do I troubleshoot?
LWelsh
Upland, CA
80UHG Series
-major brand-
80UHG Series
The thermostat runs both the AC unit and the furnace. There is no reading on the digital screen. I used a voltmeter to determine that it is out because no voltage is going to the thermostat. I've researched a bit and found out it may be due to a blown fuse in one of the units. How do I know which one it is? The AC unit is a Tempstar model N4A348AKB300 (approx 5 years old) and the furnace is a Lennox 80UHG Series that's approx 15 years old.
You'll need to look for the thermostat transformer. It's probably located on the control board for the furnace. Check for 120 VAC input and 24 VDC output. If the output voltage is correct at the transformer and not the thermostat there's a broken t-stat wire. If the output voltage is not correct you'll need to replace the board.
