True TBD-24-48 not cooling
shrinkhead
Medford MA
TDB-24-48
My 7 year old TRUE TDB 24-48 stopped cooling. Prior to this the unit was a bit warm and the compressor was running all the time. it started cooling again and next morning was at freezing temps. then shut it off and after starting again it no longer cools. replaced the temp control module; coils are clean; compressor is running and gets hot; sounds like always; all fans are spinning; drip tray is empty too;
anyone any thoughts on what to do? checking refrigerant levels? ofc since this is a commercial unit in a private residence no one wants to service it…
True is actually one of the better commercial refrigerators. Most appliance repair companies don't work on commercial units. We won't have any information on commercial machines. Call True (800)325-6152 or www.truemfg.com They will be able to tell you who repairs True in your area. If the compressor is running and there is no cooling, the problem is going to be in the sealed refrigeration system. That's going to be an expensive repair.
