Trying to find a touch panel replacement for Microwave Jenn-Air JMC1116AS0
BigTB
JMC1116AS0
Jenn-Air
Seems to be a lack of parts for this one. Anyone know any compatible models part that would work?
As far as I know there are no parts available for counter top microwaves.
Just turn table glass, drive block, fuse and glass tray wheels with nothing else :(
jeff sr.
It's a built in with a trim kit as we are using it. I haven't checked the cable connections yet and are going to look at them. Hopefully just a bad connection.
Unfortunately it is still considered a counter top style microwave.
Use to pull the cable and lightly rub a pink eraser to clean up the ribbon connections....something that helped.
jeff sr.
If you get a chance, let us know how you made out with it.
jeff sr.
Will do. And actually only the 5 key isn't working so we're limping along and hoping it's a cable connection. I hope to have time to check it this weekend.
I could live without the 5 working ;)
jeff sr.
Well, I don't have to live without the 5 as it started working! My guess(as an electronic tech) is that it is a marginal connection that will need to be dealt with at some point. These Jenn-Air appliances have been flakey and I've had problems with three out of the four.
Sounds like you are experienced so I would like to ask you a question about this microwave. It was sold to us as a built-in and is mounted that way with a trim kit. Is it really a counter top unit with no real replaceable parts in it? I didn't find any parts online and I won't bother looking for any if does have a part truly go out. I'll just look for another unit.
Thanks for the help
Terry
Yes. Add a vent and trim kit and voila....it is built in.
Yes :(
jeff sr.
