UMC5165AS Microwave "runs" when the door is open
user12345a
Alabama
UMC5165AS
Hello. My 3 year old Whirlpool UMC5165AS microwave recently started having an issue where the fan, turn-table and light run when the door is open. From a bit of research it sounds like 1 or more of my door switches may be bad. I've read references that it's possible to order a complete set which is what I'd prefer to do so that I can disassemble and repair in the same day, hopefully. :) I could not however find a parts list or repair manual and was hoping someone on this forum might be more of a search-engine-master or already know of someplace that might carry the parts.
I'm open to suggestions as well.
Thank you in advance for any help.
Cheers!
Throw away model?
You may have to contact Whirlpool to be sure but it doesn't look like they sell repair parts for it, only the turntable and support. It looks to be truly a 'throw away' model.
Microwave door switches are often interchangeable. If you took the one(s) you need to a local microwave repair depot, they could probably find a suitable replacement for it. I don't know any other way you'll get replacement parts besides have someone service it for you.
JMO
