UMC5200BAS Jenn-Air (Maytag) not heating - buzzing
rra1251
Miami, FL
UMC5200BAS
Jenn-Air
The microwave suddenly stopped heating. When started all seems normal as far as lighting and turntable spinning, it just makes a louder buzzing noise than normal - and of course no heat. The unit is part of an over/under microwave and oven setup so it is a bit of a pain to remove and get to the internals. I would love to be able to order the parts and get it fixed without having to have it sit on the kitchen floor for days while trouble shooting and ordering parts. Hopefully this is common problem is a one part deal. I did do a little research and saw on another site that it could be a couple of different things.
Thanks in advance for any advice you can give!
