RLBJr71
- KUDS24SEAL1
- KitchenAid
- More than 10 years
KitchenAid model KUDS24SEAL1 stopped working on Thanksgiving. We ran one load fine. Set it to run a second load overnight and found it had stopped mid cycle with water still in tub.
Command panel lights. Cycle will start, run water, then stop. Canceling does not drain water.
I tested fuse and it seems OK. Tested with multimeter for continuity and resistance and it seems fine although the fuse itself looks to be blackened. I tested based on Internet videos; I'm not an electrical expert, so I think it tested OK.
I also disassembled the impeller on the bottom of the tub down to and including removing the drain cover. No significant blockage found. Somewhere along the line, it caused the remaining water in the tub to leak out of the bottom onto the floor under the unit. Didn't expect that to happen. Reassembled and tried running the Rinse cycle today. It filled up with water and then stopped again. Cancel did nothing.
Any help would greatly appreciated.
Bob
Bob
