Unit Will Not Enter Cooling Cycle Without User Intervention - Amana ASD2575BRW01
NitrusInc
Southern New England
ASD2575BRW01
Amana
Hello Folks.
A week or so ago a truck snagged my powerline. The next day the freezer door was found open, with mounds of ice everywhere from water from the ice-maker. Since then, the unit has not functioned properly. It will run a cooling cycle and create cold, but once the cycle ends it doesn't seem to come back on. At least not in a reasonable amount of time.
The temp in the unit, based on a IR Thermometer, is down to negative temps in the freezer shortly after the cycle ends, but the unit never comes back on to reduce the temperature after hours.
I have replaced the Defrost Control Board and the Bi-Metal Thermostat, but the issue persists.
Banging on the control box will cause the fridge/freezer to cool properly, both before and after the "repair" last night.
Amana Side-by-Side Refrigerator US Market.
Model: ASD2575BRW01
Serial: HR52321093
Manu: 06/15
What's the next step?
Thank you for your time.
You will need to replace the temperature control thermostat to fix this problem.
WPW10583800 Thermostat
