Unreliable buttons - sometimes work, sometimes don't, sometimes completely unresponsive
akim35
USA
WED8300SW0
Hello,
A couple weeks ago, my dryer wouldn't start. The power turned on, all the buttons were in good order, the only problem was that it wouldn't start.
I tried again the next day, and it was back to normal. Since then, I've done about 8-10 loads of laundry, and it's been fine every time.
Two days ago, out of nowhere, it wouldn't start again, so I ordered a thermal fuse.
Right before I replaced it today, I noticed it wouldn't even power on (electricity was not an issue- lights were on inside the machine).
After replacing the fuse, that's when things got real wonky.
The buttons have gone completely nuts - sometimes they work, and sometimes nothing turns on.
Same with the actual drying - sometimes it goes when I press the start button, but most of the times, nothing.
I'm assuming that it is a user interface panel issue, but would like an expert opinion before I make a purchase that will cost me hundreds of dollars.
Thank you in advance!!
Angel
Hi Angel,
Are you in South Korea? Your IP address coming up from South Korea.
Where is this washer located in the USA or South Korea?
