Upgrade burner output on Jenn Air downdraft stove with grill
thomastrout
CT
JDS9860AAP
Jenn-Air
I have a JennAir dual fuel downdraft gas range JDS9860AAP SN 12275967ZU purchased used in 2010 and in use ever since. This model has 2 X 10K BTU burners on right side of cook top and 2 X 8K burners on left side due to grill unit on left, which I never used and replaced with another sealed burner unit. I would like to find out if the left side burners can be converted to the higher output capacity. Is it a question of just changing the gas orifices between the control valve and burners? Those on the left are smaller than on the right. Or are the control valves different between the left and the right? Any help I can get on this would be greatly appreciated. Thank you.
