Hi Rick,
Just to follow up on this problem, which is still not solved. After doing some digging, it turns out I only have one spark module. I found the original wiring diagram inside the front panel when I took the panel off to look for any loose wires and connections. The wiring diagram was for both a 30 inch and 36 inch. I have a 30 inch with 4 burners, so only one spark module.
I again tested L2 to Neutral with the needle tip of my voltmeter in the spade connector for L2 and neutral. I turned off the gas supply and turned on and off each valve knob and there was no voltage across the L2 to neutral with any of the four knobs. To recreate the scenario when I can light the burners with the oven on, I turned on the oven thermostat to 350 degrees and then turned the valve knobs on and voila, 120 VAC across L2 to N. Every knob turned on resulted in voltage. With the thermostat off, no voltage across L2 to N.
So I have questions. It looks like by the wiring diagram, shows a direct connection between L2 and the spark module, so why does turning the thermostat on result in voltage to the spark module? Is my oven and broiler not working a second unrelated problem, as the wiring diagram suggests the range electronics are very much separated from the oven?
