VGIC365-4QBKM Viking Oven - two burners - both start fine - one shuts off
Kbhkgeorge
Oakland, CA
VGIC365-4QBKM
Viking
I have An issue with my Viking oven. It was installed almost 20 years ago. Due to the stay at home protocols we have been cooking more. We noticed that the time it takes to warm up the oven is very long, 20 minutes plus. I took the oven apart and noticed that both burners had large holes close to the igniters. Also, one of the igniters did not turn on. After replacing both burners and the one ignite, things did not change much. I found that I could view the burners by opening the panel below the door. The sequence of events when the oven turns on are:
1) both igniters start glowing.
2) after a short time, 30 to 40 seconds, both burners lite with strong flames
3) after 15 to 20 seconds the left hand burner flames become very small and then stops
As far as I can tell, the left burner never comes back on.
In a previous thread:
The suggestion was that the igniters needed 3.2 or more amps or the gas would turn off. I tested the current and got 2.8. I then tested the current for the right side and got 2.8 also. I don’t know what to do next.
Replace both igniters at the same time. Needs to be between 3.2 and 3.6 amps
