- VGSC486-6Q
- Viking
- More than 10 years
I have a 18 year old 48" Viking VGSC486-6Q Gas Oven with Grille. The six burners, the grill, the left oven and the right broiler all work perfectly. The problem is with the right oven. Please keep in mind that this problem occurs only intermittently.
When the oven is set at a specific temperature, the temperature is reached, and the indicator light goes out letting me know it has been reached. The problem is that the gas continues to flow to the oven and the oven continues to heat and heat.
To stop this when it occurs, i must shut off the gas to the oven. This obviously make the oven no usable. I have changes the thermostat, the knob control and the relay board all to no avail. Any ideas? Can someone confirm that it is the gas valve control before I go and change that? Thank you so much.
