brianpeck
- VGS300-4BDWH
- Viking
- 6-10 years
Hi there, the place I rent has a Viking VGS300-4BDWH oven/stove in it.
The oven seems to take way too long to heat up, sometimes never even reaching the desired temp. This morning I set it to 400* (hoping to get to 350*), and 50min later it was only up to 325*. This model has a dial/knob adjustment for the temp and no actual temperature readout, but I have my own thermometer inside the oven that I use to verify temps. When cooking a sheet of bacon, I also noticed that half seemed to cook much more than the other half - this leads me to believe I probably have 1 out of 2 burners or igniters not working, uneven temps in the oven, and one burner/igniter working hard trying to heat the whole thing.
The only other weird symptom is once the oven has been on and hot, the ignition for the stovetop burners no longer works. Gas flows and they light fine with a lighter, but again once everything seems to be warm they no longer click to ignite the stovetop. Is there an ignition unit shared between the oven and stovetop that might be going/have gone bad that would cause all of these symptoms?
Any help diagnosing is appreciated!
