WA37T26G Fisher Paykel GW11 pump/diverter
hoodlum1114
Texas
GW11
We have a Fisher/Paykel WA37T26G (GW11) washer. It doesn't want to drain. I"m getting a #37 pump block error message. I checked the hoses and they're clear. I do not hear the pump engaging, but the diverter valve clicks. The diverter valve is ohm testing at 32.2K ohms. The pump is ohm testing at 5.4 ohms. I cannot find the pump fuse. I know the pump needs to be about 7 ohms, so it 5.4 too low?
I haven't worked on any Fisher Paykel machines, but this service manual should help you: https://www.dropbox.com/s/v6c376wn0q6ji79/GWL11%20GWL12%20Phase%206%20Series%2011-12.pdf?dl=0
Also, a thread Jeff helped on may help you, sounds like your water pump is blocked or clogged.
Read post #3 here: FIXED: GWL11 Fisher and Paykel washer continues to drain while in rinse cycle then throws code 37
I'd try what Gary said in post#4 of that thread:
Thanks for your help.
It turns out the pressure tube had a blockage in it. Blew in out, fixed the problem.
