pittmike
- kenmore elite
- Sears Kenmore
- 6-10 years
I have a Kenmore Elite tri door about 6 years old we got brand new. I have been fighting a water leak for a while now. There is a white plastic water line running from the top to bottom on the left side (when looking from front). For no reason it developed a pin hole leak and would only leak when the door water dispenser was in use. There is no door ice as it is a seperate unit in the freezer.
I tried to repair this by simply snipping the line and using some special 5/16" fittings I have from work made by Legris. I describe these as "chinese handcuff" style fittings. This seems to work for a while but fails again either due to pressure? or perhaps the hose keeps breaking? I also tried to use a more traditional compression type fitting but the hose broke again just above the fitting. Can the hose not take the pressure of a tight fitting and needs to be one piece run?
Any help advice would be appreciated.
Mike
Mike
