WAS20160UC Bosch washing machine failing to fill fully with water on initial wash, and on rinse cycle
JBennett
Seattle
WAS20160UC
Bosch
Washer will add water, but not enough. Clothes generally start and are not fully wet. We tried replacing the water sensor, which seemed to improve the rinse cycle a little, but wash cycle still failed to fill fully.
Serial: FD920501498
WAS20160UC is just a partial model number, there should be more digits after the UC like UC/01, UC/02, etc.
Sounds like not enough water pressure is coming into the tub, when it fills does the water flow into the tub slowly?
Did you check your water inlet valve screens where your fill hoses connect to the washer?
