FIXED Water keeps dripping inside of tub
ronniefix89
Virginia
LSN8244AQ0
I have a whirlpool washer that is about 23 years old. After the washer has finished its cycle, I am getting a small dip that is coming from the area where the washer fills up the tub. It will continue to drip into the tub even days after the washer has been used. I shut off the water to the washer, and the drip will continue for about 10 to 20 minutes. When in use, the washer fills up the same that it always has in the past. It just continues to drip after the washer is done. I am afraid that it will not stop filling during a rinse cycle and cause a flood. Any ideas what it might be?
Thank You in advance,
Ronald
Hi Ronald,
Its your water inlet valve thats bad.
Here's the water inlet valve for your model you can order here:
Water Inlet Valve 285805
Here's the video to change it:
[video=youtube_share;Fk4puRv3Vk8]https://youtu.be/Fk4puRv3Vk8[/video]
ronniefix89
Virginia
Thank you very much for your response and diagnosis I will purchase the valve this week and install it. Also thank you for the link and video.
Your expertise and willingness to share your knowledge is much appreciated,
Ronald
Ok Ronald, sounds good.
Let us know how it goes!
ronniefix89
Virginia
I ordered the part, watched the attached video and repaired the washer in 30 minutes. Solved the problem. Thank you for your great advice.
Ronald
Excellent Ronald, good job.:)
