Water Leaking From Behind Water Filter
D. Scott
Bogart GA
I have replaced the water filter in our fridge many times without a problem, but recently we have been getting water leaking from behind the water filter housing in the main compartment (its a side by side fridge). As I run cups of water it does not leak all the time. It only leaks every few glasses of water run, and then the water comes from behind the round filter housing as a short squirt. The water collects on the second shelf below it. When we were away for a week and came back there was no water at all, so I'm pretty sure it only happens when the water/ice maker is active. I really don't want to pay for an expensive repair visit on this if it is something simple. Thank you very much for any help you may have!
Make sure the "O" rings are intact...but more often than not we find a hairline crack in the housing...
Water-Filter-Housing-241521304-00987985.jpg LINK> Water filter cup and housing assembly
