dfphoto2
- WBVH6240
- GE
- More than 10 years
Hello group, I've asked for some help in the past and you were able to help me out so hoping for more good luck! My girl has a condo in Los Angeles she doesn't live there full time as she is a professor at an ivy league school. I'm one of those pesky guys who tries to fix things vs. throwing them out the unit is a GE front load washer WBVH6240 In the past few years we've tried to solve a basic problem of wet clothes (towels and bed covers mostly) being wet after a cycle, I've replaced the belt, springs, shocks, and checked the drain lines for socks and drywall screws (oops) on a basic load with 5 pairs of jeans and shirts the result was fine some banging on lower spin but not too bad on the fastest.
Switch to a sleeping bag and a towel and watch the entire 1 hour plus cycle what I noticed is the unit will not spin up to anything above 100 or so rpm from what I read and watched online it seems the unit is trying to balance itself to allow it to speed up but due to the weight it is not or the weight itself is too much.
I can spin the drum empty and it sounds fine no grinding or catching, I tried a test to see if it is the spider which is my assumption but I am not sure if there is a more accepted test than rocking the drum or semi spinning it side to side..
Or does someone have an idea of something I should test or check Thank you in advance for any help, tips, tricks, or ideas!!!
WBVH6240 approximately 2005 ish
