- WCVH6800J1WW
- GE
- 1-5 years
Hello,
I have a WCVH6800J1WW GE washer that runs through about mid cycle then stops, unlocks and the start/pause button blinks. If you press the start/pause button it will do a half spin one way then half spin the other way and then fill again with water, drain and stop mid cycle again and start/pause button blinks again. If you select the spin and rinse cycle it drains and spins at a high speed (if selected) fine. Does this sound like the inverter board or the control board?
Also, I can't get to Service Test Mode because the display is never blank and thus the signal/delay/signal/delay button press does not work. Any help on this is deeply appreciated.
laggs
laggs
