WDF520PADM6 Whirlpool Dishwasher leaks only during heavy cycle
td19128
Philadelphia, PA
WDF520PADM6
So I am getting a leak from the bottom of the door, most likely the middle, it only happens during the heavy cycle. I have already replaced a few parts (upper arm assembly, water inlet valve and float switch) but the problem persists! Not sure what to do next.Thanks!
Usually its the lower spray arm that cracks, then starts leaking water out the door. Have you checked your lower spray arm for cracks in it?
Here's the lower spray arm for your model:
WPW10491331 Arm-Spray
td19128
Philadelphia, PA
Thanks Jake, I did inspect the lower arm while I was doing the other work, no signs of any cracks or damage. I suppose I will replace it if I have no other idea how to proceed.
Its very rare to ever see this model leak, when it leaks open the door and see if its oversudsing.
td19128
Philadelphia, PA
Thanks Jake, oversudsing is not an issue. We ran a couple of test cycles without any detergent and the leak was present.
What is different about heavy cycle? Is the water level higher? Is it just a longer cycle? The unit is approximately 2 years old but used less than 10 times. It is in a rental unit.
Just a longer cycle.
Ok, what maybe happening is possibly a leak at your door vent or your detergent dispenser:
#6 is your door air vent gasket, #8 is the detergent dispenser that comes with its own gasket.
Watch this video and it will show you how to remove the outer door panel so you can see if its leaking from either of those two parts, thus running down to the bottom of your door and on the floor.
td19128
Philadelphia, PA
Jake, I did check that after the last time it leaked. I opened up the door panel. The only wet spots were along the bottom 2 inches of the door, insulation at the bottom was wet. The rest was bone dry. The area around the dispenser and vent were dry as well. The mystery continues! Thanks!
OK, have you checked the door gasket for rips or bad spots in it?
Here's the door gasket for your model:
Door Gasket WPW10524469
Ok, well I don't know where else the leak could come from, sorry I can't help you on this one.
texas
Thank you for your time and suggestions, I appreciate it.
Hi td19128, did you ever figure this out? I helped a friend by installing hers, and her dishwasher has the same problem. It's also a Whirlpool WDF520PADM6 and she bought just under a month ago at Lowes. They're offering to replace her unit, but she'll have to pay for the deinstallation/reinstallation. After she first noticed it leaking, I checked all connections and the level of the unit. Everything seemed good and the leak only occurs about an hour into any program. Quite a bit of water soaks the insulation between the door's outer and inner panels. This ain't a great time as our city is debating a mandatory "shelter in place" over COVID-19. Just curious if you think this is a known failure with this model. Thanks in advance!
