WDF520PADM7 Whirlpool Dishwasher not getting hot
Valleytech
Washington
WDF520PADM7
my whirlpool will not dry, it gets warm at best but will not dry, so far I have replaced heating element and hi limit switch, when I run the diagnostic test the clean light will blink 4 times. Any ideas?
Are sure your reading the error codes right?
I'm attaching your tech data sheet below, look on Page 7--->Service Diagnostics with Error Codes
But lets first do a reset back to default.
Anytime you replace a part on these dishwashers you always have to run the SERVICE DIAGNOSTICS CYCLE, and let it run all the way through to reset it back to default.
--->Invoking Service Diagnostics clears all status and last run information from memory and restores defaults. It also forces the next cycle to be a sensor calibration cycle.
Do that and run a cycle and see if it starts heating.:)
  • Tech Sheet - W10849767 - Rev A.pdf
