WDF520PADW - Spray Arms Won't Work
WashedOutinNM
NM
WDF520PADW
Hi all!
My less than 3 years old dishwasher is having a problem. The spray arms won't engage during washing.
Solutions I've tried:
-making sure the arms can spin (they can)
-pulled off lower spray arm, check for clogs (no clogs)
-removed the feed tube assembly (no clogs)
The dishwasher is in the range of not new, but definitely not old. So I'm a bit out of ideas.
You're missing the last digit in your model number, here's the results I get below:
https://www.repairclinic.com/Shop-For-Parts/c36-x77646635323070616477/Wdf520padw-Pump-Parts
WDF520PADW0
WDF520PADW2
WDF520PADW3
WDF520PADW5
WDF520PADW7
A common problem on these is the wash circulation motor going bad thus the spray arms won't spray at all.
So I'd first get my multimeter and take a volt reading on the 2 wires that connect to your motor and see if your 120 volts when the dishwasher should be running, after it fills.
