akashv
- WDF750SAYM3
- Whirlpool
- 6-10 years
Model: WDF750SAYM3
Bought/Installed: 2014
Problem started a few months back when water will fill and drain, but no wash cycle. First I thought it might be a board problem as I switched from Normal to Sensor mode and DW started working. After a couple of months same problem with Sensor mode, so I switched to 1-hr cycle and it started working. After a few works that stopped too.
Ran diagnostic tests 8-1, 6-4, 7-1 before diagnostic cycle followed by 6-4 and 10-1 after cycle.
My dishes haven't been drying properly and that explains 7-1.
I checked the float switch and it seems the problem is with the valve. The valve doesn't lift with the water that gets filled during any cycle. Probably requires cleaning. The switch seems to work fine tested with a multi-testes 0 ohm/infinite ohm test. It could still be a problem, but I believe it shouldn't affect the wash cycle (let me know if that is not the case); ruling out 6-4
10-1 - I noticed the detergent dispenser opens up and that shouldn't the issue with wash cycle.
Also not sure about 8-1, slow drain as water drains well and gets cleared on each cycle. I also checked the drain pipe and it is clear.
Any suggestions on what could be the issue why wash cycle never starts. Even in the entire diagnostic cycle wash cycle never started. There were multiple click sounds, pauses, water got filled, detergent dispenser opened, and in the end water drained out. But no wash.
