WDF750SAYW3 Whirlpool dishwasher stops midcycle
thiele620
Wisconsin
WDF750SAY
My dishwasher stops washing right after the soap dispenser opens. I am trying to figure out what part needs to be fixed. I have turned the power off to it several times (circuit breaker) and it doesn't help. Dishwasher starts fine, I can hear it fill and spray the dishes. Then it gets quite, the soap dispense pops open then silence. Front of machine looks like it is running (nothing is blinking). Eventually it the light goes from washing to drying to clean. I open it up, dishes are dirty and soap packet is either on the bottom or in the silverware holder. Thanks
Yes, there should be a tech. data sheet behind the bottom access panel, run a diagnostics cycle mode and let us know what you find.
If you get error code 6 4 then its a fill switch/float problem.
When you move the float switch up and down you should hear a clicking sound, also remove the float and look underneath it for something jammed/stuck underneath it, that will also cause this error code.
Here's the float switch for your model you can order if needed:
Float Switch WPW10195039
Watch this video to access it:
