FIXED WDF760SADM0 Error Codes F7 E1
Greentractorlover
Michigan
WDF760SADM0
I have a error code F7 and E1 on a whirlpool gold series dishwasher and have no place to tell what that means.....is there a tech sheet or something. I found F7 is a flow meter but everything is clean and no debris on filters or pump?
I don't have the tech data sheet for that one.
I'll see if bigbuck has it.
bigbuck
From Planet Mars
Here is that tech. sheet if you still need it.
  • WDF760SADM0 Tech Sheet - W10610059 - Rev B.pdf
Thanks bigbuck, your a gentleman and a scholar!
Greentractorlover
Michigan
Okay, so I read the ohms on the heater element and have 13 ohms, the float switch operates. The problem is that the unit does not go into wash mode but the errors are reading issues with the heater element. Could the door switch be my problem?
Greentractorlover
Michigan
Forget it.....it started working.....thinking the wire on the heater element came off or lost continuity.....it is working fine
Excellent, glad to hear you are back in business.(y)
