FIXED WDF760SADM0 Not Draining
CJerome
Upstate New York
WDF760SADM0
Good day,
Opened my dishwasher, yesterday after it completed a cycle, the dishes appear to be clean but the bottom of the dishwasher is full of gray water. Emptied the dishes and then prompted the machine to run a drain cycle, after three minute cycle no change in the water level. Checked the fine screen and it did not looked to be clogged.
welcome recommendations on next steps to troubleshoot.
Jerome
Hi Jerome,
When you pressed cancel/drain did you hear the drain pump make any sound at all?
What I usually do is remove the drain hose from the garbage disposal or sink plumbing, then get a bucket or container then put the drain hose in it and press cancel drain to see how fast the water is running out into the bucket or container, it should be a good strong flow out of the drain hose.
Did you just replace your garbage disposal? If so, then you have to knockout the plastic stopper where the dishwasher drain hose connects to on the new garbage disposal, if the water is coming out full force from the drain hose.
Also check inside the garbage disposal port where the drain hose connects to, I've seen that get clogged and prevent it from draining as well.
Drain Pump WPW10348269
CJerome
Upstate New York
Thank you for the reply. I have the dishwasher plumbed directly into a drain line.
I looked and listened and could tell the pump was pumping. Did the test to see what the output was like, it was not great certainly not strong. Checked the Second section of the drain line and that was clear which lead me to believe it was between the pump and the anti siphon loop on the side of the dishwasher. After some exploration I think it was some very small debris stuck inside what I think is a type of one way valve just inside the hose elbow which connects to the drain pump.
I ran the dishwasher until I heard water running inside and then canceled the wash to see if it would drain and low and behold it did!
I will reserve ‘mission accomplished’ until i run a full cycle, likely tomorrow.
thank you taking the time to reply to my post.
Jerome
Sounds like you got it Jerome, yes let us know tomorrow.:)
CJerome
Upstate New York
Ran the dishwasher last night and the pan was empty after the cycle! Thank you again for taking the time to share your experience. Jerome
Excellent Jerome, glad to hear that. (y)
