FIXED WDP350PAAW3 power up, lights on, but not filling or draining
Twytch
MN
WDP350PAAW3
Hi, I have a Whirlpool WDP350PAAW3 portable dishwasher about 2 years old. It powers on and lights up and control panel buttons seem to work fine, but will not fill and start the wash or if I hit cancel will not drain. I have checked door switch, float switch and inlet valve with multimeter and all came back okay. Inlet valve read 1400 ohms, clean screen and all three items had continuity.
After hand filling basin with about a gallon of water, I do the 123123123 diagnostic mode and after about 5 min it will do a wash mode and a drain mode that seems to work fine, but no fill mode at start and only grrs and noise if I don't manually fill basin with water at start. After about 20 min of diag mode all lights go off and heating element is hot.
Am I in some kind of demo mode or is my $100 control panel shot and not sending the go to inlet valve to fill? Tested to see if 120v going to inlet valve after hitting start and no juice seems to make it there.
Many days of testing and now down to hand washing dishes..ugg..please help
Yes,
If your not getting 120 volts to the water inlet valve and your float is DOWN and the float switch is good, then your control board is the culprit.
Control Board W10804120
Excellent, glad to hear that.:)
