WDT720PADM2 No Heat/ Diagnostics Mode
Ocoee
TN
WDT720PADM2
No heat, element and thermostat check good. Pump was replaced about a month ago, but it has been unplugged twice, so it should have reset. Suggestions?
How do I run diagnostic? References I see start with "turn unit on." There is no "on button. When asleep you hit any button, including start to wake it.
Ocoee
TN
Sooooo I just found Maple direction below for diagnostic mode. Running now ....
Ocoee
TN
Run diagnostics I get f7, e1, then alternating F,E. then it goes into a wash cycle. Am I doing this correct, and what does it mean?
Anytime you replace a part on these dishwashers you always have to run the SERVICE DIAGNOSTICS CYCLE, and let it run all the way through to reset it back to default.
■ Invoking Service Diagnostics clears all status and last run information from memory and restores defaults. It also forces the next cycle to be a sensor calibration cycle.
Do that, and report back.:)
