FIXED WDT720PADM2 Whirlpool Gold Series not drying dishes after pump and motor assembly
Tatkins85
Discovery Bay
WDT720PADM2
I have a 1.5 year old whirlpool gold series dishwasher.
I replaced the pump and motor assembly WPW10671941 because it stopped spraying water. After the install it cleaned and washed the dishes but I found the dishes to be soaking wet. This is an issue I was not having prior to the pump failure and install of pump motor assembly.
So, I have noticed while opening the door, the heating element does not seem to be getting hot. I have also noticed the jet dry container does not seem to be using anything and remains full. I also don’t know if I have noticed and steam coming from the vent motor at all through out the wash cycle?
Could I have messed something up during my pump assembly install that powers all of these?
That’s my last thought is, I messed up on the wiring harness or messed power up somewhere.
I have since replaced the heating element W10518394 and sensor WP661566.
I have also taken it apart and put it back together again about 10 times with no help.
Anyone have any suggestions please?
Anytime you replace a part on these dishwashers you always have to run the SERVICE DIAGNOSTICS CYCLE, and let it run all the way through to reset it back to default.
■ Invoking Service Diagnostics clears all status and last run information from memory and restores defaults. It also forces the next cycle to be a sensor calibration cycle.
Do that, and report back.:)
Tatkins85
Discovery Bay
Wow..........
After all that stress and headache. He’s of pulling it apart time and time again to see if I missed plugging something in........
It was just that reboot process, lol.
Thanks for the help!!!!
All is good
Excellent, glad to hear that.:)
