FIXED WDT790SAYB1 Whirlpool Dishwasher making high pitched sound when draining
kanbowhunter
Kansas
WDT790SAYB1
Noticed the dishwasher make a high pitched noise when getting near the end of the drain cycle. The Sump assembly was replaced 3 years ago. Sounds like the noise is coming from the pump or Sump assembly area where the drain hose comes off the pump. Would the noise indicate the pump is going out? Is it safe to run?
Doug
Hi Doug,
Yes, the drain pump on your model is seperate from the wash motor sump assembly.
I'd first remove the drain pump and check for a foreign object in it, like a seed, etc.
Here's the drain pump for your model with video:
Drain Pump WPW10348269
If you find nothing in it, its likely the bearing in it has gone bad.
Ok Doug, sounds good.:)
kanbowhunter
Kansas
Update...replaced part and fixed the high pitched noise. Thanks again for the help and providing the part to order.
Excellent Doug, glad to hear that.:)
