FIXED WDT790SAYM3 Heating element not working
Nick161024
Birchwood Tn
WDT790SAYM3
I have a whirlpool WDT790SAYM3 and I replaced the pump W11032770 and water inlet solenoid WPW10327249 because it was not pumping water. My heating element has stopped working now. What would you suggest I do?
bigbuck
From Planet Mars
Do This it may reset the computer board!1 To invoke the Diagnostics Cycle, perform the following while in
standby:
■ Press any 3 keys in the sequence 1-2-3-1-2-3-1-2-3 with no more than 1 second between key presses.
■ The Service Diagnostics Cycle will start when the door is closed.
Check if a wire came off the element or t-stat. Run the service diagnostics and check for error codes.
Nick161024
Birchwood Tn
Fixed
standby:
Running the Service Diagnostics Cycle fixed it. Thanks for your help. I guess the low water level during the run cycle caused it to cut the heating element off until running diagnostics cycle
