FIXED WDT920SADM2 Whirlpool: Water not getting hot or heating dishes
VinceFL
Florida
WDT920SADM2
Hi all!
I'm having an issue with my whirlpool dishwasher. Water is left over after a cycle. The water is not getting hot, and the unit is not heating / drying dishes at all. The unit fills with water, sprays water, and runs through its cycle without issue.
Any ideas on how to identify what the issue is? i.e diagnostic mode? Or ideas on what the culprit could be? I'd appreciate any help identifying where I can purchase replacement parts and any instructions on how to replace.
I tried looking up the manual for W10698637A but it was less then helpful when it came to parts and troubleshooting.
Thanks so much!
VinceFL
Florida
I tried running diagnostic by pressing any three buttons 123 123 123
Its running through a sequence now...ill report back what I see when its done.
VinceFL
Florida
So the diagnostic just completed...or atleast I think it did, the washer made two beeps, I opened the unit, a little bit of steam was present, and the panel was completly blank...didnt see any type of indicators...
That model number you posted isn't correct.
Your model number will start with either WDT or WDF or GU
The model number tag is located inside the door on the inner tub or inner tub frame.
VinceFL
Florida
Update here, I replaced the heating element W10703867 and its still not heating water or drying dishes.
The model # is WDT920SADM2
Does anyone have any other ideas of what the issue might be?
I am running the diagnostic cycle now, I hit 3 buttons consecutively and closed the door and its running through a cycle, not quite sure what to look at/for once it completes for error codes?
Anytime you replace a part on these dishwashers you always have to run the SERVICE DIAGNOSTICS CYCLE, and let it run all the way through to reset it back to default.
■ Invoking Service Diagnostics clears all status and last run information from memory and restores defaults. It also forces the next cycle to be a sensor calibration cycle.
Do that now, and report back.:)
Excellent Vince, glad to hear that.:)
