"Weak" Jenn-air
Mdrowe
NY State
My 20-year-old Jenn-air range just got "weak," i.e. it has power and the breakers seem OK but the fan doesn't work, the oven light is on but dim, and all elements only get warm. In my ignorance, I assume it is getting only 120 V when it wants 240 V. Is there some internal fuse that could shut off half of the power or some such?
Model#?
Very possible. Bad house fuse, 1/2 tripped breaker, burnt wire ( in the range or in the house power line for the range ).
Mdrowe
NY State
Hi Jeff,
Thanks for your thoughts. It is Model D120.
I just came home from dinner, and the light no longer works at all. I think you are right about a burned wire. We just happened to catch it in the middle of burning out.
Michael
Model#?
jeff.[/quote]
Mdrowe
NY State
Jeff:
As usual, most simple things have simple solutions.
In checking for bad wires as you recommended, I took out the drawer under the range and found that the plug had been bumped halfway out of the socket because the drawer hardware had come loose and the drawer had gone in crooked. The plug was in the socket just enough to make the lights work and not much else.
We had planned to cook Christmas dinner at a friend's house and cart it all home. Now all is well.
Aloha and Happy Holidays,
Michael
