- WED4800XQ3
- Whirlpool
- 6-10 years
Hi, our dryer is not tumbling consistently. Started with shutting off mid cycle and wouldn't restart.
Replaced:
Belt
Both rollers and one axle (it had a worn down groove from a scratched up roller)
Completely cleaned out the vent shaft to the ground and the back of the motor.
Motor turns freely and drum finally turns w/o anything in the dryer.
Trial/Errors:
On Air/Fluff, tumbles a few slightly damp t-shirts through a 30 minute cycle
On Low heat, tumbles a few slightly damp t-shirts through a 30 minute cycle
On Low heat, tumbles a slightly larger load only about 5 minutes before kicking off and feeling overly warm inside.
On Low heat, tumbles a 95% dry towel for less than 1 minute before kicking off (this also included 3 fabric dryer balls)
ETA:
On Air/Fluff, tumbles one wet (not sopping) towel through a 30 minute cycle
On Low heat, tumbles one wet (not sopping) towel through a 30 minute cycle
I have three last things in mind at this point, but don't want to necessarily buy all three, especially since I just realized that it's nearly 10 years old (based on Serial Number).
Bearing Ring for front of tub
Seal for rear of tub
Drive Motor
Other trials I could run or suggestions as to what to look at next?
Replaced:
Belt
Trial/Errors:
ETA:
Drive Motor
