- WED4815EW1
- Whirlpool
- 6-10 years
In auto/Accudry, the dryer just keeps running. In timer mode, the timer will advance, but not in auto. I think my model is older because most of what I've found online with this problem and this model number have either moisture sensors or circuit boards, neither of which my dryer has.
I replaced the cycling thermostat and that didn't work. I was fairly confident the timer itself was fine but I replaced it anyway and it didn't help. I did see on another post where someone with a similar problem found the orange wire from the high limit thermostat to be loose and that fixed their problem. Mine doesnt appear to be loose but I'm wondering if the high limit thermostat itself could be the problem. It doesn't make sense that it would be since it is normally closed and if it failed I'm assuming I wouldn't get any heat.
I've also seen a lot of suggestions dealing with airflow and obstructions. I took the vent loose and ran it with the same problem. Plus, the clothes are drying just fine.
I'm looking over the wiring diagram and trying to make sense of it. Any ideas on what else could be holding the timer out from advancing?
