FIXED WED6400SW1 Whirlpool Dryer not running
snake61047
Freeport IL
WED6400SW1
Hi and thank you
I was able to pull the f31 code. what i found on the internet stated that the code meant that i had low or 0 voltage on one of my lines going to the dryer. I have since checked and have 124v on both lines going to the dryer and a good ground. Wife said it just quit working mid cycle. I evebn reset my breaker just t
I'm attaching your tech data sheet below. There is no F31 on this model, It stops at F30.:)
Do the console lights come on, but the dryer won't start?
I'd first ohm test your thermal fuse with a multimeter. Unplug your dryer first before taking it apart and ohm testing the thermal fuse.
Here's the thermal fuse for your model you can order here, if yours is bad:
Thermal Fuse WP3392519
Watch this video to access it:
snake61047
Freeport IL
Yes the lights all come on. Then when you hit start it goes into sensing mode and then does nothing. You can hear a click when you press start. and again when you hit cancel coming from the machine. Why in the heck would it hive an f31 code in none exists? I will ohm it tonight when i get off work. Thanks for the help.
Josh
snake61047
Freeport IL
I also started reading the tech sheet and performed the voltage test. The machine is seeing 24v per the sheet. the less light is lit up and display is as 24-25.
snake61047
Freeport IL
If you read the tech sheet It tells you how to get the dryer to display voltage that it reads. It does this by giving you the second two numbers of the voltage on the digital display then it uses less normal more lights to tell you the range. Normal would be a hundred volts more would be 200 volts less would be zero volts. So my dryer was reading less and then read 24 which means the dryer is only seeing 24 volts instead of 124 volts per leg. Hope this helps
Then you have a electrical problem in your home breaker box.
You should be getting 240 volts between the two HOT 120 VOLT LEGS.:)
You said you had 120 volts on each leg not across each leg. Put your meter probes on each of the outer two terminals on your dryer's terminal block and see if you get 240 volts.
Ok good, now let's test for Ghost Voltage. Put the dryer on TIMED DRY 40 minutes.
Keep your meter probes on the outer two terminals on the dryer terminal block and have someone press the start button on the dryer and see if the volts drop below 100 volts.
Ok, then ohm test the terminal fuse.
LOL, sorry my bad, yes thermal fuse, damn typo!
Yes, that indicates the thermal fuse is the culprit.
The number 1 cause of a thermal fuse to blow out is a vent restriction either in the vent exhaust hose in the back of the dryer or outside where the vent duct vents outside.
Whenever I replace the thermal fuse I always Pull the dryer out from the wall, then check that vent exhaust hose for lint clogs, and go outside the house and do the same where it vents outside.
snake61047
Freeport IL
will do thank you so much. is that fuse available at like the big box store and any other store i would find locally?
Its not available at any big bix store, only online at my link to it above in post #2, or at a appliance parts store in your area if you have one.
