WED87HEDW Whirlpool Duet Dryer Won't Turn On/Zero Power
amymcbrew
Hope Mills, NC
WED87HEDW
About a month ago I noticed my dryer was taking forever to dry clothes. Now it won't even turn on! I did check to make sure it was plugged in properly, and checked the breaker, and it was fine. Could it be a fuse? Please advise!
WED87HEDW
I found WED87HEDW0 and WED87HEDW1
http://www.applianceaid.com/model-number.php Some model# helps.
Checked the venting? Vent hood? Lint filter?
A copy:
Q - My dryer is dead, what could do that ?
A- Common problems...blown house fuse/tripped breaker ( electric dryers need 2 )...loose white/neutral wire...broken belt ( on some models only )...door switch/door switch bracket...*thermal fuse open ( venting needs attention )...broken or burnt wire...timer...motor...burnt power cord/plug...start switch ( especially the ones with a built in relay switch )
* If you find a blown thermal fuse, always clean, change, adjust the venting system and vent hood first.
If needed:
Thermal-Fuse-WP3392519-01993779.jpg Dryer thermal fuse located on the blower housing
[video=youtube_share;3nicyh6EUHc]https://youtu.be/3nicyh6EUHc[/video]
