WED9200SQ0 I am unable to reset fault codes
jenkins-ear
Kenney, TX
WED9200SQ0
Dryer shows the same fault codes as were present when we had a thermistor go bad -a year ago - all F25's. I am unable to reset those. I have tried powering dryer off (both via unplugging at wall and tripping breaker) for 5 minutes and 30 minutes, but alas - the codes remain. Have also tried some funky key sequences I found elsewhere (do not recall now what they were), but suffice to say they did not work.
Trust me - our thermistor is ok. How can I clear those codes?
I looked over your tech. data sheet and there is nothing in it that shows you how to clear the error codes, so don't worry about.:)
You will only see F-25 in diagnostics, not when the dryer is running in normal cycles.
Then if you get any future error codes they will come first before the F-25 one.
Glad to help.:)
