bmbouter
- WED9200SQ1
- Whirlpool
- More than 10 years
Today our Duet Dryer runs anytime the door is closed even if the dryer isn't "on" according to the front panel. The only way to get it to stop is to either open the door or interrupt power at the breaker. It is not warm, it's just spinning. While it's spinning with the door closed and "off" I can turn it on with the power button on the front panel, select a cycle and run it at which point it runs normally with heat, the cycle ends according to the display, but then doesn't stop spinning.
What can I do to fix this? How can I verify the root cause of the issue?
Brian
Brian
