WED92HEFW0 Whirlpool Dryer touch panel quit working.
bingduby
WED92HEFW0
Whirlpool WED92HEFW0 dryer touch pad stopped working. Only illumination is drum light when selector knob turned to desired setting.
I'm attaching your tech data sheet below.
If no indicators come on after selecting the cycle, go to TEST #1, CCU Power Check, page 11.
bingduby
Followed test 1 through step 9 which says reassemble and verify repair even though no repair made. Both voltage tests were positive for voltage at specified connectors. Turned unit on and appears to be functioning now. Some other threads state it will work a day or two and stop again requiring a CCU replacement. What say you?
Ok, its intermittent then, that's going to be hard to nail down till it stops working altogether. I'd first check your electrical wire harness cable that runs between the User Interface and the CCU, make sure its tight and no pins are backing out.
Wire Harness W10837344
Here's the User Interface for your model:
Here's the CCU for your model:
Control Board W10875487
