WED9600TA0 Disassembly Instructions for teardrop/trim ring
PRINTER888
Plantation, FL
Model
WED9600TA0
The Trim Ring has come loose and need to remove it so that I may reattach the clips or as a final resort buy a replacement that has the clips attached. Any help would be appreciated..
Here are the instructions on removing and replacing that trim:
1. Unplug dryer or disconnect power.
2. Remove the three screws from the top panel, and slide the top panel to the rear to remove.
3. Gently remove the decorative trim that surrounds the door and upper console by unsnapping it from the machine.
4. Slide the console up and off of the machine.
Here's the trim clips:
WPW10129065 Clip
Here's that trim assembly that comes with new clips:
WPW10180500 Trim
