- WED9600TA1
- Whirlpool
- 6-10 years
Duet dryer runs but does not heat. I went to the customer's house to check it out. It is in a narrow closet sitting on top of the matching washer. I could not access the top without pulling it out and putting it on the floor, but then the cord doesn't reach the outlet.
I removed the bottom panel, and checked the element, the HL-thermostat, and the thermal cut-off. Those were all good. I checked live voltage readings. I get L2 voltage to the heater (through the motor switch, I assume), but no L1 voltage to any of the parts I checked. I would at this point assume the control board is not putting out L1 voltage to the heater circuit.
I forgot to check the thermistor(s), but would they cause this symptom? Or would they cause an error code instead?
Is there a diagnostic manual for this model? I did not see one in the lower panel.
