WEG745H0FS0 Whirlpool Range F2E1 code Caused by ribbon cable shortage
tpony
San Diego
WEG745H0FS0
Whirlpool WEG745H0FS0 F2E1 code, unplugged no fix. I found connector ribbon cable between touchpad and control board was burnt a little, plastic is gone, which left 2 metal line touched stove body shortage, I wrapped the connector and test it ok ,reinstall, still the F2E1 code (stuck or shortage keys)after reboot 30 seconds. The switch membrane seems ok, no keys fail, should I replace the control board or switch membrane first?
Anyone have idea which part the ribbon shortage most likely damage?the switch membrane works fine, no continuous beep sound, every keys responds pushing, if you have the circuit please provide, thanks a lot !
They're not sold separately so if you can't fix that one you'll need to replace the control.
