WF316BAC/XAA Samsung front loader nd code
Lynnsrepairs
whitehall ny
WF316BAC/XAA
Samsung
any help out there for a nd code that is not a pump or clog My washer works up until it wont drain
I verified pump is good and no obstruction in drain hoses I get no power to pump when it should call for drain mode. is there a relay or fuse that is typical failure point? I can put power to pump and drain machine no problem Im thinking it may be control board? Thanks
Lynnsrepairs
whitehall ny
Thanks for the reply jake
one more thing the user had the washer overfilled
I read somewhere that it might be excessive suds/detergents in line to level switch?also any suggestions on source for board maybe even used or can it be repaired
Yes, possibly, flush all the suds out with COLD WATER ONLY.
I really have no clue where to get the board, sorry.
