WF328AAR/XAA Samsung washer tub won't move
jefdod
Ms
WF328AAR/XAA
Samsung
I have a Samsung washer that the drum is locked up and will not turn. The rotor and stater are good and bearings look good.
What is the model number of your machine?
Click here: Appliance Parts
jefdod
Ms
Model # WF328AAR/XAA. The tub is running out of balance. Took apart and found spider gears broken and outer tub damage.
Then you'd need a new spider support and a new outer tub assembly.
Your missing the last 4 digits of your model number, here's the results I get:
WF328AAR/XAA-0000
WF328AAR/XAA-0001
WF328AAR/XAA-0002
The last 4 digits are very important to ordering the correct spider support and outer tub assembly.
Your welcome.
