WF419AAW/XAA Samsung - Inner washer tub
JR Mills
Texas
WF419AAW/XAA
Samsung
I have front load washer model # WF419AAW/XAA. The washer was leaking from the front. So I thought it was the boot seal. Took wAsher apart pulled seal nothing wrong. Cleaned the tub up and replace boot seal. Turn on it was leaking again. Found a crack in the wash tub. Use som plastic bond to fix crack. Put it back together work fine. So I left it running. this morning I go to get the blanket out and I noticed that the inter tub is very loose. WhAt happen? Did I throw the bearing. Or possibly when I was cleaning it and spinning it around and around mess some thing up.
