Xkse
- WF42H5200AP/A2
- Samsung
- 1-5 years
Hi
My washer has started having similar problems to others with the 3E2 error...cycle starts but drum doesn't spin. Happened intermittently at first and now the drum won't go at all, even in test mode.
Followed the fast track troubleshooting sheet, stator measuring 11-12 ohms (troubleshooting sheet says 6 but everywhere i've found people have been getting readings of 11-12).
On the fast track sheet, page 9 has a troubleshooting section specific to the inverter board, and you're supposed to get 4.6 ohms, but i'm not getting anything near that. Based on the other threads, i figured i'd start by replacing the inverter board since the stator and rotor look ok.
Three questions:
Three questions:
- My board is DC92-01378C which has been discontinued. Is an acceptable replacement DC92-01531B? Someone else on the forum seems to have used this and had ok results.
- When I took the rotor off, I broke a section of the stator (the ceramic section near the bolt holes, not the windings). Resistance is still reading 11-12 ohms as shown above. Is this ok as long as the windings are intact and it is structurally ok?
- What kind of threadlocker should I use to put the rotor back on?
